NatalyLevesque
Multi-group analysis in JMP
Hello community!
I want to do multi-group analysis in JMP. For example, I have 150 Instagram respondents and 130 YouTube respondents. I don't know how to create two groups (pooled variables) and then do the analyzes. I don't want to compare or join: just do regressions / Anova to compare the responses of the Instagram group to that of YouTube.
Am I clear? Can you help me?
Thank you :)
Nataly
P_Bartell
Level VIII
Re: Multi-group analysis in JMP
There are many different data visualization or modeling approaches that can be used. In general you'll want to create a single column that is labeled something like "Social Media Platform", then each row will hold either an Instagram or YouTube value. From there all JMP platforms will need is you placing this column into a model (using say Fit Model) as an effect or for visualization just drag and drop onto an X axis in a Graph Builder workflow. This should at least get you started?
It sounds to me that you need to go through the Discovering JMP document to familiarize yourself with what can be done, and an introduction on how to do the items you are looking to accomplish. The document is under the Help pull down menu.
