DavidLeber
Multi-User Access
I'm working on a solution which will live on a network drive, to be accessed by multiple users asynchronously. Specifically, I have several "database" tables that users will add rows to, where the rows then contain links to their full submitted datatable.
Is there any built-in way to manage file access permissions in a situation like this? I want to avoid a situation where a user opens the "database" table and forgets to close it, locking everyone else out of the tool. I could code in my own variation on a mutex, but I don't want to reinvent the wheel if there is a built-in, easy solution. The ideal solution would be some sort of JSL script that sends a row of data to a data table without taking the lock on the data table.
David_Burnham
Re: Multi-User Access
Just to be clear, when you say "database" tables, you mean JMP tables?
I'm not aware of any ability to perform row locking - JMP is inherently single-user so I assume it doesn't have that ability.  This is what I do:
openSharedTable= Function({filePath},{default local},
	isLocked = 1;
	nAttempts = 200;
	delay = 0.1;
	attempts = 0;
	While(isLocked & attempts < nAttempts,
		attempts++;
		dt = open(filePath,Invisible);
		value = dt << Get Table Variable("Locked File");
		If (value=="",
			isLocked = 0
			Close(dt,NoSave);
			Wait(delay);
	return(dt);
-Dave
David_Burnham
	isLocked = 1;
	nAttempts = 200;
	delay = 0.1;
	attempts = 0;
		attempts++;
		If (value=="",
			isLocked = 0
			Close(dt,NoSave);
			Wait(delay);
	return(dt);
-Dave
