wu
wu
Is there way to search the files including the subfolders, instead of Files In Directory(path)"
The command "Files in Directory(path)" only search files listed in the path,
I'd appreciate if anyone could advise on how to search the subfolders under the path directory
Thanks!
Craige_Hales
Re: Is there way to search the files including the subfolders, instead of Files In Directory(path)&q
You want the recursive option:
Use the Help menu to get to the Scripting IndexUse the Help menu to get to the Scripting Index
Craige
Craige_Hales
Craige
