jach
Multi File Import of network folder slower in latest JMP version
In JMP 14, Multi File Import of a network folder was relatively fast.
For example, it takes ~11 seconds to load the below folder.
With JMP 16 on the same computer/folder/network, it will first spend almost 3 minutes while "discovering files", before proceeding with the above "loading file names" step.
Are there any settings or options that I could change to skip the "discovering files" step?
Thank you for your help.
0 REPLIES 0
