mostarr
Insert() Not Functioning as Hoped
I'm using Insert() as indicated in the Scripting Index,
Insert(list, stuff, <optional index>);
I'm excluding the optional index in my case.
To test my code, I created a dummy variable, temp, initiated it with
temp = {};
then every iteration of my for loop (where other things work and I'm sure it is basically structured correctly--though I realize that is a vague statement and possibly has some holes in it) I add the result of an output variable to temp. Outside after the for loop I Write() temp. The result is an empty list, {}.
I don't know why Insert() isn't working, even in "test mode".
Thank you all for being such an accommodating community. I realize I throw a lot of errors your way.
Mike
Re: Insert() Not Functioning as Hoped
A quick guess is that you really want to use
Insert Into()
Insert Into()
mostarr
Thank you muchly, @txnelson, I don't know why that works but it does. JMP is such a strange language to me, coming from Python.
Jeff_Perkinson
The documentation for List Operators and Functions is useful here.
Insert Into()
Insert Into(list, x, <i>)
Inserts a new item (x) into the list at the given position (i). If i is not given, the item is added to the end of the list. This function does change the original list.
Insert()
list = Insert(list, x, <i>)
Returns a copy of the list with a new item (x) inserted into the list at the given position (i). If i is not given, the item is added to the end of the list. This function does not change the original list.
-Jeff
