bernie426
Moving new column
As an example on the Big Class.jmp, I will like to move the created new column after age column.
As the script below, the move selected columns script does not work, the new column still created at the end.
Can anyone help this out? Many Thanks,
Open( "$SAMPLE_DATA/Big Class.jmp" );
New Column( "example", Numeric, Continuous, Width( 5 ), <<Set Each Value( 100 ) );
<<Move Selected Columns({"example"},After("age"))
ms
Super User (Alumni) ms
Re: Moving new column
Eval() would not be not needed if assigning a Column() instead of a string to myAfter
Example:
myAfter = Column(dt, "sex");
dt << New Column("example", <<Set Each Value(100), <<Set Selected(1));
dt << Move Selected Columns(After(myAfter));
Vball247
Level V
Thanks, good to know, this helps because I do pull a list of user selected columns in my script using << Get Selected Columns. Was going off the syntax guide, where it seems that After("name") acts like Column(dt,"name"). I'm still confused by a list of columns vs. a list of column names vs. a list of character strings of the column names and where they can be used to reference a column.
You can also move columns without first selecting them in the data table by using the following syntax.
dt << Move Selected Columns( {"name"}, To First );
dt << Move Selected Columns( {"name"}, To Last );
dt << Move Selected Columns( {"name"}, After( "name" ) );
6 REPLIES 6
bernie426
Sorry, I found that should be
dt=Current Data Table();
dt<<move selected columns({"example"},After("sex"));
syl022
This can be done by a simple procedure. In your data table, go to "Cols" and select "Reorder Columns." Then, you can change the order of the column as you want. Wish it helped.
Vball247
Level V
It appears not to like sending the message to the assumed current data table, your code was not specifying it. It works if you specify the data table as below. I am working on something similar, new column that I want to replace the old column in a large number of columns for the user, so it is in the same location that they are used to seeing it. My text string goes where "example" should go, but now getting the Move Column dialog pop-up. At least I know the "After" should work. Using JMP13.0.
dt = Current Data Table();
dt << Move Selected Columns({"example"},After("sex"));
Vball247
Level V
Here's my problem. If I use a variable for the After("name") it goes to the dialog:
myAfter = "sex";
dt << Move Selected Columns({"example"},After(myAfter));
If I evaluate by using After(Eval(myAfter)) it works. If you have a variable in the list, also has to Eval first.
myAfter = "sex";
dt << Move Selected Columns({"example"},After(Eval(myAfter)));
ms
Example:
Vball247
Level V
