Here is a script that I believe will give you what you want
dt = New Table( "Untitled 5",
Add Rows( 30 ),
Compress File When Saved( 1 ),
New Table Variable( "Moving Avg Window", 5 ),
New Column( "DateTime",
Numeric,
"Continuous",
Format( "m/d/y h:m", 19 ),
Input Format( "m/d/y h:m" ),
Set Values(
[3225888000, 3225888900, 3225889800, 3225890700, 3225891600, 3225892500, 3225893400,
3225894300, 3225895200, 3225896100, 3225897000, 3225897900, 3225898800, 3225899700,
3225900600, 3225901500, 3225902400, 3225903300, 3225904200, 3225905100, 3225906000,
3225906900, 3225907800, 3225908700, 3225909600, 3225910500, 3225911400, 3225912300,
3225913200, 3225914100]
New Column( "data",
Numeric,
"Continuous",
Format( "Best", Use thousands separator( 0 ), 15 ),
Set Values(
[5, 5, 5, 5, 5, ., 5, 5, 5, 5, 5, 5, 5, 5, ., 5, 5, 5, 5, 5, 5, 5, ., ., 5, 5, 5, 5,
5, 5]
New Column( "expected run avg",
Numeric,
"Continuous",
Format( "Best", 12 ),
Set Values(
[., ., ., ., 5, ., 5, 5, 5, 5, 5, 5, 5, 5, ., 5, 5, 5, 5, 5, 5, 5, ., ., 5, 5, 5, 5,
5, 5]
New Column( "run avg",
Numeric,
"Continuous",
Format( "Fixed Dec", 12, 1 ),
Formula(
If( Row() == 1,
NonMissingRows = dt << get rows where( Is Missing( :data ) == 0 )
If( Loc( As List( NonMissingRows ), Row() ) < :Moving Avg Window,
TargetPosition = Loc( As List( NonMissingRows ), Row() );
MatrixofMAW = NonMissingRows[Index(
TargetPosition - (Moving Avg Window - 1),
TargetPosition
Show( Row(), MatrixofMAW );
Sum( :data[MatrixofMAW] ) / :Moving Avg Window;
