Dennisbur
Move Rows
Hello
I have calculated the table, but I want to move rows in this table.
For example, I want to move the GPIO row to the start of the table and the JTAG row after GPIO.
I tried to write this script, but something went wrong, can you assist me with this script?
dt << Move Rows ( {"GPIO"}, At Start );
dt << Move Rows ( {"JTAG"}, After( "GPIO" ) );
Re: Move Rows
<< Move Rows seems to work with selected rows
r = dt << Select Rows([5, 7, 8, 10]);
Wait(2);
r << Move Rows(At Start);
Re: Move Rows
My suggestion is to open the Value Ordering column property, and change the order of the values in there, and then just sort the data table based upon the Parmeter column, and it will follow the Value Order you specified.
Dennisbur
Re: Move Rows
Is there a script command to move rows in a table?
Re: Move Rows
Here is one way of moving a row:
DT = Current Data Table();
rowToMove = dt[5, 0];
dt << delete row( 5 );
dt << add rows( 1, after( 12 ) );
dt[13, 0] = rowToMove;
Re: Move Rows
Wait(2);
