In contingency analysis along with mosaic plots the default order is reversed between the plot and the table
Notice that in the plot the first entry is San Francisco and the last is Boston. In the table however the order is reversed with Boston first and San Francisco last. This cause some mental gymnastics when looking between the two. I have found that if I set the axis in the plot to be reverse then things line up.
Then things line up nicely between the plot and the table
Is there anyway to make this the default setting for the mosaic plots?
