lmartingate
Mosaic Plot Axis Formatting Help
I have created a mosaic plot with pages for different categories of data. For one page, of the 7 possible x-axis categories, only 6 are represented in the data (the 7th category has zeros as data and does not appear in the plot). For the second page, only 3 of the categories are represented in the data. The problem is, my x-axis labels don't match up. All 7 labels are listed no matter how many categories of data there actually are. Additionally, the labels do not line up with any of the mosaic plots.
Any help would be appreciated! Willing to explain further if need be.
KarenC
Re: Mosaic Plot Axis Formatting Help
Try fix Y by X with your page variable as the by variable and see if the plots from fit Y by X help.
KarenC
lmartingate
Good call, thanks!. Definitely a bug in the graph builder though.
