Rajat
Mixed Stacked and Side-by-side Bar Graph in JMP
I have a data with all numerical values. How would I plot mixed of Mixed Stacked and Side-by-side Bar Graph in graph builder. I want to plots my graphs as shown in attached 2 images.
First image only shows the percentage of each variable in mixed of stacked and side-by-side bar plot but in Second images also shows the value of the variable as well.
If you can share the detailed procedure or JSL script, that would be great help.
Below is the sample data.
Student Total_Math_Physics Maths Physics Total_Badminton_Football Badminton Football
A 50 30 20 40 10 30
B 40 25 15 20 10 10
C 30 15 15 50 40 10
9 REPLIES 9
Rajat
Re: Mixed Stacked and Side-by-side Bar Graph in JMP
@txnelson Can you please look into this. I believe you must have the solution.
ron_horne
Hi @Rajat
your question is a good one but i do not think JMP can do this on the fly.
please see attached my file with the scripts to produce the output. my approach is more of a low-tech solution. i have added columns to calculate the shares for each subject and (fake) rows to allow for the side by side effect. once this is done i modified some things in the graph properties to complete the illusion.
please let us know if this is in the right direction.
ron
Rajat
@ron_horne for replying :)
I posted only sample data. I have many more variable that just 4 as well as many observations. This approach might be very tedious to my original data set as it have lot of manual work.
Rajat
Thanks @ron_horne for replying :)
Can We have different approach as data I have, has many variable as well as observations. It would be very tedious for me to modify data as per the posted approach.
Rajat
@jules
Earlier you helped me bar plot doubt. Can you also please look into this?
Appreciate your help.
jules
Hi @Rajat
I think we can get pretty close to what you want with only a little bit of work:example graph.png
I've attached the restructured data table with the saved script so you can look for yourself. Here's what I did:
1. Stack your original table:
Current Data Table() << Stack(
	columns( :Maths, :Physics, :Badminton, :Football ),
	Source Label Column( "Label" ), Stacked Data Column( "Data" )
This gives the following:table.png
2. We need a variable that will let us split up the grouping of activity (maths/physics vs badminton/football), so I'll add a new column, Group, and iterate A-A-B-B-A-A-B-B, etc. You can do this any way you like, you just need a nominal variable. Here's another way with Sequence():
New Column("Group", Numeric, "Nominal", Formula(Sequence(1, 2, 1, 2)) );
3. Graph Builder:
I tweaked a number of settings to get the graph looking the way I did, but here are the basic steps and a short video:
(view in My Videos)
Steps:
  1. Drag "Data" column to Y role
  2. Drag both of the "Total" columns, at the same time, to the top of the Y drop zone
  3. Toggle off the points, and toggle on the Bar element
  4. Change the bar style for the lower graph, "Data," to "Stacked"
  5. Drag "Label" to the overlay role
  6. Under the controls for the top bars, turn off the overlay role under "Variables"
  7. Drag "Group" to the X axis role
  8. Turn off "Group" variable for upper plot in the control panel
  9. Drag "Student" to the Group X role
  10. Change "Summary Statistic" for the lower graph to "% of Factor" (I neglected to show this in the video)
  11. Change label to "Label by Value" for each bar
This gives:example plot.png
From here you can do a lot. For the final graph I showed at the beginning, I also made some additions like changing the bar widths (right click a graph > customize), removed the X axis labels (double click axis and uncheck labels), and also changed the Graph Spacing (Red Triangle> Graph Spacing). Here is a script for the final graph:
Graph Builder(
	Size( 799, 566 ),
	Graph Spacing( 2 ),
	Variables(
		X( :Group ),
		Y( :Total_Math_Physics ),
		Y( :Total_Badminton_Football, Position( 1 ) ),
		Y( :Data ),
		Group X( :Student ),
		Overlay( :Label )
	Elements(
		Position( 1, 1 ),
		Bar( Y( 1 ), Y( 2 ), Overlay( 0 ), Legend( 5 ), Label( "Label by Value" ) )
	Elements(
		Position( 1, 2 ),
		Bar(
			X,
			Y,
			Legend( 4 ),
			Bar Style( "Stacked" ),
			Summary Statistic( "% of Factor" ),
		Dispatch(
			"Group",
			ScaleBox,
			{Min( -1.167069008972 ), Max( 2.147362067225 ), Inc( 1 ),
			Minor Ticks( 0 ), Label Row( Show Major Labels( 0 ) )}
		Dispatch(
			"Total_Math_Physics",
			ScaleBox,
			{Min( 0.23109243697479 ), Max( 55 ), Inc( 10 ), Minor Ticks( 1 )}
		Dispatch(
			"Data",
			ScaleBox,
			{Min( 0 ), Max( 1.1209749344709 ), Inc( 0.2 ), Minor Ticks( 0 )}
		Dispatch( {}, "graph title", TextEditBox, {Set Text( "Example" )} ),
		Dispatch( {}, "X title", TextEditBox, {Set Text( "" )} ),
		Dispatch(
			"Graph Builder",
			FrameBox,
			{DispatchSeg( BarSeg( 1 ), Set Width Proportion( 0.6 ) )}
		Dispatch(
			"Graph Builder",
			FrameBox( 2 ),
			{DispatchSeg( BarSeg( 1 ), Set Width Proportion( 1 ) )}
		Dispatch(
			"Graph Builder",
			FrameBox( 3 ),
		Dispatch(
			"Graph Builder",
			FrameBox( 4 ),
		Dispatch(
			"Graph Builder",
			FrameBox( 5 ),
		Dispatch(
			"Graph Builder",
			FrameBox( 6 ),
I hope this helps!
@jules
Rajat
Thanks @jules, its a really nice solution.
Only I wanted to put the student variable to the x-axis instead of using it as group by variable because my dataset have 60 observations for student variable and each observation have long name and if I put the name as groupby function,its name gets trimmed of and it gets very hard to understand the graph. But if I can put it on X-axis. I can make the name verticle.
If I put the student on X-Axis with Group variable, it shows me two same values for each group which is incorrect.
Once Again Thanks @jules
Really Appreciate your help :) :)
jules
Hi @Rajat,
That makes perfect sense. But, as you discovered, variables used in the X-role behave a bit differently, and Graph Builder will plot both levels of the grouping variable for the top plot. Using the Group X gets around this, but unfortunately, there aren't controls for the label orientation for the Group X variables the same way there are for the Group Y, and X-axis roles. This could be a good item for the JMP Wish List! For now, the best advice I have is to shorten the labels if you can.
@jules
Rajat
@jules
I also want to put one continuous variable also on Y-axis and because of using student as grouping variable, this also not working properly. If you do get more robust solution, please do let me know.
Thanks @jules for your great help :) :)
