tajrida
Missing course data set in Virtual JMP - Statistical Thinking for Industrial Problem Solving Online course
Please advise:
Upon selecting the vleuser drive in Virtual lab JMP online, there is missing or no folder with the name "workshop" that contains couse data set. I am only seeing the window folder which is empty.
Mohammed Ahmed
21 REPLIES 21
Alexia
Re: Missing course data set in Virtual JMP - Statistical Thinking for Industrial Problem Solving Online course
I started the Statistical Thinking for Industrial Problem Solving course and am now at the second module, Exploratory Data Analysis. I have reached the first practice exrcise, which requires to open the "Chemical Manufacturing.jmp" file. As I Don't have JMP, I am using the virtual lab.
So, I created my account, but in the data file of the virtual lab, there is no "Chemical Manufacturing.jmp" file.
I refreshed the data several times, and each time the message "data refreshed successfully" appeared on top of the page. But still, I cannot find the "Chemical Manufacturing.jmp" file.
However, this file does exist in the downloaded data for this course. I cannot open it because I do not have JMP.
Can you either add this file or guide me to import them from the dowloaded course data on my computer?
Thank you very much in advance
Alexia
Well, as it often happens, I found the files just after asking the question… Sorry for the inconvenience.
The files are thus in S:\workshop\EJMPST. The access to this directory has been disabled, however, when doing a search for a specific file on "This PC", like Crisis TeamData, or Chemical Manufacturing, they appear there and can be opened.
A nice day to you all!
Our paths just crossed : )
Glad you were able to find the files!
Mia
lil
lil
Nope I don't have this folder
Have you been able to find any of the course data files in JMP on the virtual lab? This is my view. When I follow the path to the course folder, vleuser > workshop > EJMPST, I see the Chemical Manufacturing data set.
If this doesn't help, can you please write [email protected]
They can help you figure out what the problem is.
Thanks! Enjoy the course!
Mia
lil
lil
I don't Workshop file folder at all. Where can I find these so I can practice?
If you don't see the workshop folder as described in another post, please log out of the JMP Virtual Lab, click Refresh your Data, and then launch the virtual lab again.
When you go to File > Open in the virtual lab, you should see a vleuser folder. The course data are in the workshop subfolder.
If you are not seeing this folder, please contact our education technical support team at [email protected].
I hope this helps!
Mia
Pom_Kharel
I am using JMP Pro 17 virtual lab. I do not see EJMPST in workshop folder. I did all the steps as mentioned in solution sections above. Very sad, no luck.
Hi @Pom_Kharel ,
In the Virtual Lab, double-click on the "learnsas..." folder under This PC. You should see the workshop folder. When you double-click on this folder you should see the EJMPST folder. Double-click on this to see the STIPS data sets. If this doesn't help, please reach out to [email protected].
Mia
Pom_Kharel
Hi Mia,
I do not see any thing inside the folder "workshop", even not EJMPST. Please see the screenshot.
