yanee
How to import control limit to column property?
I have 2 separate files. One is the raw data and another is the control limit file.
How can I import all the control limit to the raw data file column property ? This is for Levey Jenning control chart.
Re: How to import control limit to column property?
I believe you need to return the column names a character strings for the Get Rows Where() to work
ColList = dt<< get column names (numeric,string);
Byron_JMP
 Make a control charts in Control Chart Builder
Use get limits to get the control lists.
Use Save Limits to save the limits to the column property
There are several other ways to do this.
yanee
I try to select get limit but nothing happened. Any idea why ?
yanee
I try to do the for loop ..
dt is my raw data.dt_spec is the spec file.
things seem to work except on the line below
limrow = Try( (dt_spec << get rows where( dt_spec:Label == ColList[i]))[1], . );
it doesn't return the number of rows. However, when I replace ColList[i] with the name, it works fine.
Any idea why ?
ColList = dt<< get column names (numeric);
for(i=1, i<= n items(ColList),i++,
	controllimits = {Levey Jennings(LCL( b ), UCL( c ) )};
	Substitute Into( controllimits, Expr( b ), dt_spec:_LCL[limrow] );
	Substitute Into( controllimits, Expr( c ), dt_spec:_UCL[limrow] );
	Column( dt, Char( ColList[i] ) ) << set property( "control limits", Eval( controllimits ) );
