I suspect the value given with the prediction formula out of the new SVM platform with a missing categorical input is incorrect and it should not be displayed. If you need to handle missing data, I suggest using a different platform (for example, Explore Missing Values under the Analyze > Screening menu) to impute those values first, then move to SVM.
At least in my test cases, when saving a prediction formula with a missing input all of the intermediate columns return missing, and the final formula is just the first possible result. When you just save Predicteds, then those rows are missing as expected.
