SDF1
JSL Syntax Change is coming: Name() is being deprecated
Hi All,
  I just read here that the JSL syntax for referencing a column using the Name() parser is going away. The new syntax is currently in use and at some point the old syntax will be removed entirely. There's a lot of people here who script, so thought it would be good to post something here.
  I know I have a lot of code I'll need to change! Better to be ahead of the curve and change it before it's too late.
DS
0 REPLIES 0
