Method for calculation of degrees of freedom?
Hi!
I was wondering if anyone knows how JMP calculate degrees of freedom? I think SAS is using the Satterhwaite approximation, but I cannot find any information about if JMP use the same?
Thanks!
Jeff_Perkinson
Re: Method for calculation of degrees of freedom?
Hi Sandra,
From Chapter 7 of Fitting Linear Models:
Degrees of Freedom
The degrees of freedom for tests involving only linear combinations of fixed effect parameters are calculated using the first‐order Kenward and Roger correction. So JMP’s results for these tests match PROC MIXED using the DDFM=KENWARDROGER(FIRSTORDER) option. If there are BLUPs in the linear combination, JMP uses a Satterthwaite approximation to get the degrees of freedom. The results then follow a pattern similar to what is described for standard errors in the preceding paragraph.
For more details about the Kackar‐Harville correction and the Kenward‐Roger DF approach, see Kenward and Roger (1997). The Satterthwaite method is described in detail in the SAS PROC MIXED documentation (SAS/STAT 9.2 User’s Guide, Chapter 56).
-Jeff
-Jeff
Jeff_Perkinson
Hi Sandra,
Which JMP platform are you looking at?
If it's Fit Model, which personality are you using?
-Jeff
-Jeff
I am working in JMP 9.0.
I just open my data table, then go to analyze - fit model. In the box that opens, I specify the different parameters:
1) the dependent variable in Y below "Pick Role Variables"
2) and other variables below "construct model effects". These are both continuous and nominals, one is random and there are at least 2 interactions included in the original model.
The other settings I use are:
Personality: Standrad Least Squares
Emphasis: Minimal Report
Method: REML (Recommended)
Unbound Variance Component are also used.
Thanks in advance!
/Sandra
Jeff_Perkinson
Hi Sandra,
Degrees of Freedom
-Jeff
-Jeff
Ok, thank you for you help!
/Sandra
