I am working in JMP 9.0.
I just open my data table, then go to analyze - fit model. In the box that opens, I specify the different parameters:
1) the dependent variable in Y below "Pick Role Variables"
2) and other variables below "construct model effects". These are both continuous and nominals, one is random and there are at least 2 interactions included in the original model.
The other settings I use are:
Personality: Standrad Least Squares
Emphasis: Minimal Report
Method: REML (Recommended)
Unbound Variance Component are also used.
Thanks in advance!
/Sandra
