aumair
Merging graphs in same window
I am running a loop that subsets a data table and plots a variability chart from the subset table. Script is something like below:
//lot list is a string list...
lot_count = Length( lot_list);
For( i= 1, i <= lot_count, jj++,
      subset a data table from main table depending on some criteria
      do gymnastics with the subset table and plot a variablity chart
); // for loop closed. At the end I will have a number of variablity charts in separate windows
What I wanted to do is to merge all the plots in same window...
My approach is to use something like this after the loop is finished:
New Window( "Combined graphs", lineup box(ncol(2), v1, v2, v3,v4););
But I am having trouble in:
1) Assigning a variable v1, v2, v3, ... to a variablity chart based on the interation number within the loop
2) Provide dynamic list to New Window(), where each variable of list {v1, v2, v3, ...} is refering to a variablity chart.
Thanks in advance for any help! A different approach would be acceptable!
Re: Merging graphs in same window
Here is a simple script illustrating what you are asking for:
dt = Open( "$SAMPLE_DATA/blood pressure.jmp" );
// get the numerical columns
numColumnNames = dt << get column names( numeric, string );
// Create an output display window
New Window( "Combined graphs", lub = Lineup Box( N Col( 2 ) ) );
// Loop accross the variables and add them to the Charts to the display
For( i = 2, i <= N Items( numColumnNames ), i++,
	vc = Variability Chart(invisible, Y( Eval( numColumnNames[i] ) ), X( :dose ) );
	lub << append( Report( vc ) );
	vc << close window;
pmroz
Can you use graph builder and drag the lot number to the "Wrap" role?  That will automatically create a separate mini-graph for each lot number.
aumair
Thanks for your suggestion. I wanted this to be fully automated - would look into graph builder scripting! Also after subsetting the table, I am doing various things with the subset table. If I do these operation on the main table, it would get a bit complex - sorry probably difficult to explain :)
	vc << close window;
LSYAW
Hi txnelson,
Thanks for the suggestion.
I tried with one original image and a crop image manage combine to a new window and save in journal. But somehow the original image was replaced by the crop image. and the size of the image were the same.  Wander if you have a way fix it.
img = Open( "$SAMPLE_IMAGES/tile.jpg", JPG );
nw1 = New Window( "Original Image", img );
{w, h} = img << Get Size;
img << Crop( Left( 50 ), Right( w - 50 ), Top( 50 ), Bottom( h - 50 ) );
nw2 = New Window( "Smaller Image", img );
nw = New Window( "Combined Images", Lineup Box( N Col( 2 ), nw1, nw2 ) );
nw << Save Journal( "/C:/Users/User/Desktop/My Processed Image Journal.jrn" );
TQ
ECLSYAW
aumair
Thanks a lot txnelson!!
append() made it so easy - and I didn't know about that.
