Jaz
Jaz
Merging Rows
I was just wondering if there was away to merge two rows from the same data table using JSL? I was contemplating using the Join function but I'm not entirely sure how that will work.
Thanks.
15 REPLIES 15
chessknt87
Re: Merging Rows
Thank you for your reply. The problem is that I want it to create new column labels since the data in the table has nothing to split by. If I group by subject and ask it to split value and date what do I pick for split by? I want each observation to just be listed under a new column created for a duplicate observation
Subject   Value Date               Subject Value Date  Value2 Date2 value3  date3
A              1          x                     A           1        x          2         y       .            .
A               2          y      ---->        B           3       z          4         g     5           f
B              3           z
B               4          g
B               5          f
Re: Merging Rows
Create a new column that gives a sequence number for each of your subjects
if(row()==1,counter-1);
If(lag(:subject) != :subject, counter=1, counter=counter+1);
counter;
Then you can split by the new column
Re: Merging Rows
Hi! I've got a similar problem. I'd like to merge rows with the same time value without creating new columns. So in the example below rows 75629 and 75630 would become one row with more data in it and 75631/2 would move up one number. Is there a way to do something like this?
Jeff_Perkinson
Re: Merging Rows
If it's a matter of dealing with the missing values for those columns you might try using Tables->Summary to group by your datetime column and use the Max statististic for all those columns.
-Jeff
plfazeli
Re: Merging Rows
You mentioned this in a post a few years ago "I've had data sets where there were multiple rows that needed to be "combined" into a single observation.  How to do it depended on whether I wanted the average or sum (or....) of those rows."
Can you tell me how to do this? (I would want a sum of the value in a variable for unique subject IDs with multiple rows of data)
Re: Merging Rows
Use the Summary platform
Tables=>Summary
