kocemba
Merge two rows of data
Hi
I have a list of patient ID's, diagnosis and diagnosis date. I have it like this right now:
IDLabelRow 1Row 2Row 3Row 4Row 5Row 6Row 7Row 8
1Diagnosisxxyyzzxx
1Diagnosis date01/01/200001/01/200101/01/200201/01/200301/01/200401/01/200501/01/200601/01/2007
2Diagnosis
x
xyyzzxx
2Diagnosis date01/01/200001/01/200101/01/200201/01/200301/01/200401/01/200501/01/200601/01/2007
I am trying to get it like this:
IDDiagnosis datediagnosisDiagnosis datediagnosisDiagnosis datediagnosisdiagnosis dateDiagnosisdiagnosis datediagnosis
101/01/2000x01/01/2001x01/01/2002y01/01/2003y01/01/2004z
201/01/2000x01/01/2001x01/01/2002y01/01/2003y01/01/2004z
Can you help?
Thanks!
KarenC
Re: Merge two rows of data
You can use the table split:
Tables > Split
Then Split By = Label
Split Coumns = Rows
Group = ID
I like to click the "Keep dialog open" option as it often takes a couple of rounds to get things just right.
You can do this by using the Split Platform
     Tables==>Split
Which creates the following output data table
The order of the rows is based upon the alphabetical order of the Label column.  So if you want to change that you can use the Value Ordering Column Property to change the order
And then the final data table will look like:
KarenC
Tables > Split
Split Coumns = Rows
Group = ID
kocemba
Thank you KarenC!
     Tables==>Split
kocemba
Thank you txnelson!
