word function changing a String into separate numeric values
I currently and trying to separate out numberic values that are stored in a single column as a string in this format: "[email protected]@32"
I am trying to use the word function to create new columns with single numeric values with this jsl:
dt<<New Column("New", Numeric, Continuous,
Formula(word(1,:Column,"@")));
but jmp will automatically change this to a categorical column. Is there a way to force it to be numeric?
Jeff_Perkinson
Re: word function changing a String into separate numeric values
JMP changes the data type of the column to a character because the Word() function returns a character string.
You can use the Num() function to convert a character string to a numeric value.
Formula(num(word(1,:Column,"@"))));
-Jeff
Jeff_Perkinson
-Jeff
MathStatChem
Try this:
Formula(Num(word(1,:Column,"@"))));
