Dongjin
May I change Color of Col' head????
I have a quick question.
Can I change the color of the JMP data table col' head?
As you can see now, we are dividing by changing the color of the cell,
but it would be great if we could only change the head, not the whole.
(Actually, I think it would be better if we could form a group by column on data table toooo)
Thank you..
Georg
Re: May I change Color of Col' head????
Don't think that is possible, at least not for the table object (if you need it for display only, maybe you should create a report thereof).
But there are other possibilities to structure the table,
of course you can group columns (in the column panel of the table),
and probably "Recode Column Names" may help you to restructure the Table.
Recode Data in a Column (jmp.com)
Additionally you can hide and exclude columns as well ...
Georg
