New to JMP? Let the Data Analysis Director guide you through selecting an analysis task, an analysis goal, and a data type. Available now in the JMP Marketplace!
I'm using the PDF Import Wizard in JMP 17.0. Is there any way to maximize the size of the Wizard window? I don't see any buttons for max/min in the upper right.
