ILoveJMP
Max value of each row across multiple columns and the corresponding name of the source column
Hi, is there an easy way to find the max value of each row and the column name (or parameter) corresponding to the max value? Below is a simple example to illustrate the request:
T1T2T3T4T5T6T7T8T9T10Max_ValueCol_Name (Parameter)
87.283.681.48383838382.383.384.687.2T1
85.984828483.383.3848386.587.287.2T10
84.982.7868382.382.3838283.685.286T3
85.684.682.784.684.384.384.383.684.986.286.2T10
85.283.68283.3838383.382.384.385.685.6T10
86.884.382.784.383.683.684.383.385.986.286.8T1
86.28482.3848783.383.68384.985.987T5
88.184.682.384.383.68484.383.385.986.288.1T1
85.683.381.783.3838383.682.78485.985.9T10
37.436.136.436.436.136.136.435.436.737.437.4T1
36.734.534.834.533.834.134.533.536.136.136.7T1
34.832.933.232.932.232.53631.933.835.136T7
3836.436.436.436.436.136.7393838.339T8
3835.135.14034.134.534.833.836.43740T4
Re: Max value of each row across multiple columns and the corresponding name of the source column
The data table subscripting is new in JMP 13.
You can try something like this idea to build an expression that will create a row vector matrix from the current row when evaluated.
dt = New Table( "Untitled",
    Add Rows( 3 ),
    New Column( "first", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [1, 5, 9] ) ),
    New Column( "second", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [2, 6, 10] ) ),
    New Column( "skip", character, setvalues( {"a", "b", "c"} ) ),
    New Column( "third", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [3, 7, 11] ) ),
    New Column( "fourth", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [4, 8, 12] ) )
names = dt << getcolumnnames( "numeric" ); // returns a list of all numeric column names
Show( names ); // {first, second, third, fourth}
Substitute Into( names, Expr( {} ), Expr( Concat() ) );
Show( Name Expr( names ) ); // first || second || third || fourth
Row() = 2; // names will pull data from the current row
rowvec = (Eval( names )); // [5 6 7 8]
Given a list of row names, the Substitute Into() function replaces the curly bracket list operator with the concat function. Concat function is the same as the || concatenation operator and can take a lot of arguments. The concatenation evaluates each column reference in the list for the current row. The individual scalar values are concatenated into the row matrix.
21 REPLIES 21
DataMojo
Looking for the exact same solution.
For each row find max value and return column name so i can run statistics on the resultant data.
Eg to find how many times a column name shows up as maximum, the number of columns that contribute to max value, the STD DEV etc.
// this example uses JMP 13 data table indexing
    New Column( "a", Numeric, Set Values( [1, 33, 1] ) ),
    New Column( "b", Numeric, Set Values( [2, 2, 2] ) ),
    New Column( "c", Numeric, Set Values( [333, 1, 0] ) ),
    New Column( "maxval", numeric ),
    New Column( "maxcol", Numeric )
colnames = dt << getcolumnnames;
For Each Row(
    r = Row();
    // 1::3 means columns 1 through 3.  {a,b,c} would also work.
    location = Loc Max( dt[ r, 1 :: 3] ); // location of maximum value in array
    maxval = dt[r, location];
    maxcol = colnames[location] << getname;
Data table with maximum value from row and name of maximum column for rowData table with maximum value from row and name of maximum column for row
Earlier post on data table subscripting
DataMojo
I have run into one issue here, if the columns I need to choose are between the data set it doesnt seem to work.
For Each Row(
    r = Row();
    location = Loc Max( dt[ r, 57 :: 113] ); // location of maximum value in array
I need to choose columns 57 through 113, but for some reason when I do this it through the script off and i get incorrect values.
DataMojo
Resolved i was missing the offset of columns that had to be added to the location variable.
Good point. The example could be generalized like this (intentionally ugly column arrangment...) Pick one of the either/or that works best for you. The 2nd one has the advantage of isolating you from accidental rearrangements of the columns. The first one might be good for 100s of columns.
    New Column( "maxcol", Numeric ),
// either
vars = [2 4 5];
colnames = (dt << getcolumnnames)[vars];
// or
colnames={a,b,c}; // this might be best choice
For Each Row(
    row = Row();
    location = Loc Max( dt[ row, colnames] ); // location of maximum value in array
    col = colnames[location]<<getname;
    maxval = dt[row, col];
    maxcol = col;
ILoveJMP
It still doesn't work properly for me. Attached please find both the script and the data files. Could you please let me know what I did wrong here?
The script and data table worked great for me.  Now, I did change the
     dt=Open("........");
to
     dt=current data table();
Since the table was already open.
So, I would suggest that you try that, or that you place an additional statement after your dt=Open statement:
     wait(0);
There is a chance that your data table has not finished before the For Each Row starts.  The Wait(0); will force the open to complete before running the For Each Row
ILoveJMP
Thanks much Jim for the reply! However, it still doesn't work for me with dt=current data table(). Not sure what is going on. BTW, could you send me the output file you generated?
Here is the data table after I ran the script
