ThomasDickel
Map Value function: Inconsistent results for subsequent calls
I am new to JMP 16 and JSL but I am an experienced programmer.
For some reasons I want to use the "Map Value" function but this gives me wrong results.
What i want to achieve is to remove unwanted items given as a list from a list containing numbers and strings
The following function constructs a list for "Map Value" named na_values in the form {option1, 0, option2, 0, ...} from the na_list e.g. {option1, option2 ,...}
and filters it using "Filter Each" and the Map Value" function.
wrap = function({filtered list,na_list}, {Default Local},
		na_values={};For Each( {value}, na_list, na_values=Insert(na_values,value);na_values=Insert(na_values,1););
		return(Filter Each({value}, filtered list, Map Value(value, na_values, Unmatched(0))==0;));
But it gives a wrong result if I call the function again with other parameters:
Show(wrap({"b",1, 2, 3},{"b"}));  // <--  returns {1,2,3} => OK
Show(wrap({"d",1, 2, 3},{"d"}));  // <--  returns {"d",1,2,3} => NOT OK, should be as above {1,2,3]
What is wrong here? A bug in JMP? I am using version 16.0.0 (512257).
Best regards,
Thomas
ThomasDickel
Re: Map Value function: Wrong results for different characters
The JMP support has answered me, it may be a defect which I have found.
Their support gave me the following solution to my original problem to remove unneeded items from a list using the Associative Array function:
filtered list = {"b", 1, 2, 3};
na_list = {"b"};
result = Associative Array(filtered list) << Remove(Associative Array(na_list)) << Get Keys; // {1, 2, 3}
6 REPLIES 6
ErraticAttack
Sometimes JMP / JSL can be weird in how it handles expressions -- for instance, often times in a send function the arguments are sent unevaluated.  Although there is no send function here it would seem that something within the Filter Each() or Map Value() handles arguments in a weird way and handles the lookup oddly.
Basically, I cannot say that it is a bug but it does seem weird.  If I were you I'd contact JMP Support and show them that the first call (whether it's the {"b",1,2,3"} or the {"d",1,2,3}) works, while the second does not work.  Possible that it's a bug.
Here is a work-around:
wrap = Function( {filtered list, na_list},
	{Default Local},
	na_values = {};
		Insert Into( na_values, value );
		Insert Into( na_values, 1 );
	Eval( Eval Expr( Filter Each( {value}, filtered list, Map Value( value, Expr( na_values ), Unmatched( 0 ) ) == 0 ) ) );
Jordan
David_Burnham
I'm not sure how you got your function to work without first initialising na_value as an empty list.  This works:
names default to here(1);
filtered list = {"d",1, 2, 3};
na_list = {"d"};
na_values = {};			// <--- missing
f = Filter Each({value}, filtered list,
show(f);
-Dave
ThomasDickel
Hello, you are right, I removed the initialization of na_values from my test function.
But the problem exists if I add the initialization of na_values to the function:
Show(wrap({"b",1, 2, 3},{"b"})); // = {1, 2, 3}=> OK
Show(wrap({"d",1, 2, 3},{"d"})); // = {"d", 1, 2, 3} => Not OK ! => expected {1, 2, 3}
Please try yourself the above code.
David_Burnham
In your example
doesn't give the correct results for the 2nd call.
But this works:
Which would suggest that you shouldn't need to throw evals all over the place.
The issue is that the 1st call to the function works, and subsequent calls fail; which is very strange.
-Dave
ThomasDickel
Thanks for your reply. As you have said the first call works, the subsequent calls fail.
I have called our JMP support about this problem which has given this issue to its technical support team. If I get any news to that I will post it here.
ThomasDickel
na_list = {"b"};
