Jackie_
Manage spec limits
I am trying to get write a jsl code which will disable the manage spec limits but there seems be an error. Need some advise
It works well if number of columns are less but not with larges data sets with more columns
dt2= current data table();
dtx = dt2 << Get Column Group( "Tests" );
								new window("", modal,
							ob = Check Box( {"Check to hide limits"},
								ou = ob << get selected;
								If( ou != "Check to hide limits",
									dt2 << Manage Spec Limits(
												Process Variables( Eval( dtx ) ),
												Show Limits All( 0 ),
												Save to Column Properties( 1 )
Re: Manage spec limits
Here is some code that seems to work
names default to here(1);
dt2 = current data table();
msl = Manage Spec Limits(
	Process Variables(
		eval(dtx)
	show limits all(0), save to column properties(1)
msl<<close window;
