Agustin
Make combined data table with script
Hi I'm using the Variability chart and looking at the variance components. When I right click the Variance components table it gives me the option to make combined data table, is it possible to translate this step to jsl instead of the manual right click?
Thank you
David_Burnham
Re: Make combined data table with script
Do it manually and take a look at the table that is produced.  It will contain a table script which contains the JSL to produce the same outcome.
-Dave
Agustin
This fixed it:
platform[1][Outline Box( "Variance Components" )][Table Box( 1 )]<<
Make Combined Data Table;
David_Burnham
-Dave
Agustin
Hi David, how do I look at the table script? I tried using the log functionality but it didn't show anything.
Thanks
Agustin
Hi I found what you meant however when I try to run it this error comes up:
platform = Data Table(
	"table"
) << Variability Chart(
	Y( :measurement ),
	X( :Lot, :Instrument, :Operator, :Site ),
	Model( "Main Effect" ),
	Variance Components( 1 ),
		Dispatch(
			{"Variance Components"},
			"CV",
			NumberColBox,
			{Visibility( "Visible" )}
Wait( 0 );
Report( platform[1] )[Outline Box( "Variance Components" )][Table Box( 1 )] <<
Report( platform[1] ) << Close Window;
That's the code for reference, firstly it's missing several variability charts, but even when I add them manually the same error pops up. Any ideas?
Agustin
This fixed it:
