MargauxR
Make a combined data table from text exlporer
Hello everybody,
I have some trouble to create my combined data table from a script.
I try to make a script to analyse a table with word and samples.
I do manually the text explorer of word (called "Termes" in my data table) by samples (called "Num Ech" in my data table) and than i create a combined data table to have a data table with the count of each word by sample.
I found a script to do the text explorer, but i don't understand how to create the combined data table. this is my script :
dta3 = Current data table ();
dta3 << Delete Columns("MOTS");
LV = dta3 << Select Where(Is missing(:TERMES));
LV << Delete Rows;
txt = dta3 << Text Explorer(
	Text Columns( :TERMES ),
	Tokenizing( "Basic Words" ),
	Language( "French" ),
	by( :NUM ECH ),
Report(txt)[Outline Box("Liste des termes et des phrases")][Table Box(1) ]<< Make combined Data Table;
Any idea ?
Thank you !
Margaux
Margaux R
ms
Super User (Alumni) ms
Re: Make a combined data table from text exlporer
The problem may be that you have a By( ) column that adds another layer to the report. The variable txt is then not a Text Explorer object but a list of several objects.
I don't have French JMP installed, but try the code below. The only difference is the index [1] that points to the first "sub-report".
Report( txt[1] )[Outline Box( "Liste des termes et des phrases" )][Table Box( 1 )] <<
Make Combined Data Table;
MargauxR
Thank you, it's working !
Have a good day !
Margaux
Margaux R
