oscarmforero
Make Combined Data Table from Journal in jsl
Hi community!
I have the attached Journal, and I want to make a combined data table from the Summary Statistics and Capability Analysis. I checked the tree structure, but I'm unsure on how to make the correct reference. I was trying with the below but it didn't work. Any clues?
Current Journal()["Summary Statistics"][Tablebox(2)] << Make Combined Data Table;
Re: Make Combined Data Table from Journal in jsl
You are off by one Table Box().   This code will create a combined table for the Summary Stats and then a separate combined table for the Capability Analysis
Current Journal()["Summary Statistics"][Tablebox(1)] << Make Combined Data Table;
Current Journal()["Capability Analysis"][Tablebox(1)] << Make Combined Data Table;
oscarmforero
Great!
So, how is the indexing works?
When looking at the tree structure, it is TableBox[2]. Or is it because I've already pointed to the ["Summary Statistics"] that the TableBox index is reset to 1?
