hogi
Level XIII
Main Menu("command") - return value?
If I open a file via open("filename"), the command returns a reference to the data table which can be used as
dt = open("filename");
If I trigger open via
dt = Main Menu("open")
it doesn't return a reference to the data table.
In general, is there a way, when triggering a command from the Main Menu, to get the return value?
e.g. a reference to a data table for a user defined file loader - or an error code of the AddIn?
0 REPLIES 0
