Achim
MSA - getting repeatable
I am a new user off JMP. Something is fishy. I am getting a zero EV value on every MSA calculation. First I started with a destructive MSA, here I thought oh well maybe it has something to do that I cannot repeat the measurement on the same part.
But here is a simple resistivity measuring MSA , crossed, so there for sure should be an EV value stated.
What am I doing wrong, must be some simple setting..!??
JMP file attached.
P_Bartell
Level VIII
Re: MSA - getting repeatable
I do not see an attached file?
Achim
I guess It removed the file.
I am getting the error message: The attachment's lehighton 5 27 21.jrp content type (application/octet-stream) does not match its file extension and has been removed.
What is this all about?
It is a JMP with a JRP extension. Anyone?
Ryan_Gilmore
Hi @Achim , my apologies for the difficulty in uploading the report file. We are working on getting this fixed.
In the meantime, you can zip the file then upload the zipped file. Hope that helps and sorry for the inconvenience.
While I haven't looked at your file, it is likely you have not filled out the input fields appropriately. It is not intuitive as it could be...Check the JMP help to make sure you have complete the fields correctly.
