TONG_SUPER
MM/DD HH:MM conversion how to do
I have a time Colum in a odd format  ( do not even have Year in and  need help converting to a simply   YY/MM/DD HH:MM
Thanks
tong
Time
[08/06-19:07:34.981]
[08/06-19:08:05.927]
[08/06-19:08:14.270]
[08/06-19:08:26.331]
Re: MM/DD HH:MM conversion how to do
Here is the formula I used to do the conversion
Date MDY( Num( Word( 1, :Time, "[/" ) ), Num( Word( 2, :Time, "[/-" ) ), 2024 )
+Informat( Word( 3, :Time, "[/-]" ), "hh:mm:ss" )
TONG_SUPER
Thank you so much
TONG_SUPER
I had another question.  I can do MM/DD/YYYY but i do not know how to add the time string in to add in it
Source Table
20240207_163752
20240208_132212
20240320_180945
20240321_062705
DMY conver=Date DMY(Num( Munger( :Source Table, 7, 2 ) ),Num( Munger( :Source Table, 5, 2 ) ),Num( Left( :Source Table, 4 ) ))
JMP Date/Time values are stored as the number of seconds since Midnight, January 1, 1904.  So once you have input the Date part using the DateDMY, the time part just needs to be added to the date part. The time part simply becomes the number of hours*3600 + number of minutes*60 + number of seconds.  I don't know how to interpret the 163752, but all you need to do is to determine the number of seconds in the day it represents and then add it to the Date part, and you will have your answer.
TONG_SUPER
sorry i was not clear.  163752  is kind of military time for  HHMMSS  eg 4 pm 37 min and 52 sec
Given the method I specified above, the formula is
DMY conver = Date DMY(
) + Num( Munger( :Source Table, 10, 2 ) ) * 3600
+Num( Munger( :Source Table, 12, 2 ) ) * 60
+Num( Munger( :Source Table, 14, 2 ) )
There are a lot of different methods of converting strings to datetimes in JMP. Building it from ground up by splitting it from parts is the method which has the highest success rate but there can be easier methods, such as Format Pattern (note that In Format() has << Use Locale argument which you might need sometimes)
strs = {"20240207_163752", "20240208_132212", "20240320_180945", "20240321_062705"};
For Each({str}, strs,
	datetime = Informat(str, "Format Pattern", "<YYYY><MM><DD>_<hh24><mm><ss>");
	Write("\!N", str, " converted to time is ", datetime);
20240207_163752 converted to time is 07Feb2024:16:37:52
20240208_132212 converted to time is 08Feb2024:13:22:12
20240320_180945 converted to time is 20Mar2024:18:09:45
20240321_062705 converted to time is 21Mar2024:06:27:05
If using as formula replace str with your column
https://www.jmp.com/support/help/en/18.0/#page/jmp/datetime-functions-and-formats.shtml# - Scripting Guide
https://www.jmp.com/support/help/en/18.0/#page/jmp/date-and-time-functions.shtml#ww2531887 - JSL Syntax Reference
