doctorfizz
Loop through reports and extract title
I am trying to loop through all reports generated from an ANOVA-oneway. I create a list of the reports anova_list.
If I manually try to extract the title from a report with the following syntaxt
curr_anova = anova_list[1]
report_title = curr_anova << report << get  title("string")
the output is what I expect - some variation of: Oneway Analysis of Y by X by1=by1val by2=by2val ...
But when I try to do this in a loop
for(i = 1, i<= n items(anova_list), i++,
curr_anova = anova_list[i]
the output of report_title is DisplayBox[OutlineBox].
Am I making an oversight on the syntax? I have tried different combinations of evals to see if the output change, to no avail.
Re: Loop through reports and extract title
Try changing
to (the brackets being the most important)
report_title = (curr_anova << report) << get  title;
Try changing
doctorfizz
jthi,
thanks for the suggestion. This indeed does the trick!
May I ask why this is different? What does the containment with parenthesis do?
Your original version created a 'message cascade:"
result = obj << message 1 << message 2;
The result is from the succession of messages to the same object. Using the parentheses sends the second message to the result of sending the first message.
