melsie999
Logistic regression with multiple outcome variables
I am running logistic regression analyses on a dataset where the outcome has multiple categorical variables.  In this case, I am using total number of humans present (continuous variable) to predict the behavior of gibbons (the behaviors are categorical).  I am trying to use the parameter estimates to determine which specific behaviors are affected by the number of humans, but I am having trouble interoperating the results.  I can see the results for each individual behavior, and the Wald test to show whether that behavior is affected by number of people, but the last behavior alphabetically on my list (vocalize) does not output any numbers, so I do not know how to see if this variable is affected.  Am I interoperating these results correctly?  How do I see if the last behavior (vocalize) is affected by number of people?
25 REPLIES 25
Re: Logistic regression with multiple outcome variables - Odds ratios in JMP
Yes, each row (individual) will get a result from the formula for the odds.
Yes, you can use the mean odds. Use Table > Summary or Analyze > Tabulate to get the results for each group or subgroup.
The hand calculation is as you say Pr(group A) divided by Pr(not group A) or whatever. The odds ratio would be the ratio of the odds under different conditions (treated, untreated).
astachowicz
Hi Mark,
I am performing a multinomial logistic regression for an outcome variable with three levels.  I have been trying to figure out how to find the odds ratios and finally came across this previous answer from you.
How do I save the probability formulas?
Thank you in advance.
Click the red triangle at the top of the platform and select Save > Save Probability Formula.
astachowicz
Thank you for the prompt response.
Alternative to saving the probability formulas and calculating the odds ratios myself, I had independently saw at the bottom of the parameter estimates data display on my multinomial logistic model that is says "for log odds of Outcome A/Outcome C, Outcome B/Outcome C" where Outcome C is my reference outcome.  Is it possible that I can just calculate the odds ratio by transforming this data into a data table, inserting a new column with the formula exp(Estimate)?
I found a separate post that references this as well -->  https://community.jmp.com/t5/Discussions/Logistic-regression-with-multiple-outcome-variables/m-p/110...
It seems almost too easy to be true.
Thank you again.
It is not true. That way is also not easy at all. It is more difficult than using the Save command. The parameter estimates are not estimates of the odds or odds ratios. That note is just a re-statement of the logistic regression problem. You have the linear predictor on the right side of the model equation and the logit function on the left side. The note that you see at the bottom of the Parameter Estimates table is just a record of what logits were used with the linear predictors.
If you save this table of estimates, then you have to create a column formula to compute the logit value for each row. Then you have to add another column formula for each response level to back-predict the probabilities. That is what the Save > Save Probabilities command does for you.
irinastl
I am using JMP 13 Pro, not a student version.
irinastl
Are there tutorials/videos for logistic regression with multiple outcomes?
I checked our learning assets but found no tutorials about nominal logistic regression. (See items from selecting Learning JMP on the JMP home page menu.) I then checked our YouTube account and found this tutorial about Multiple Logistic Regression. There is also Logistic Regression Introduction with Tutorial in JMP on YouTube. It covers logistic regression more thoroughly but only for the outcome. It does not cover multi-nomial logistic regression.
We offer this training course, which covers this topic: Analyzing Discrete Responses. We cover the origin, use, and interpretation of such models as well as how to preform this regression in JMP.
plf515
You can't do logistic regression with multiple dependent variables in one run of logistic. But perhaps you have ONE dependent variable - behavior of gibbon - with multiple levels?  How is "behavior" operationalized? Is the data something like this:
Case ID Num People      Behavior
1               3                    A
2               2                    B
3              5                     A
4              2                    C
etc.? Or does each gibbon engage in multiple behaviors? Or is each gibbon engaged in multiple cases? (in that case, you'd need some form of multi-level model, probably with GLIMMIX?
melsie999
It is like you have laid out.  The gibbon only does one behavior at a time, but it has several behaviors it can do, such as feed, travel, vocalize, groom, etc.  What I am trying to do is see how the number of people present affects the likelihood of the gibbon doing a certain behavior e.g. does the gibbon reduce time spent feeding when more people are present.  The logistic regression tells gives me a p value for the entire model, so I can see that number of people does affect gibbon behavior, but what I would like to do is see which individual behaviors are driving the model - I'd like some sort of stats with p values that show me which behaviors are actually changing.  All I am doing now is looking at the output figure and describing how the behaviors change.  Here is what the output looks like.  I tried to insert the figure, but it wasn't working.  I have figured out though, that I cannot do the odds ratio test because my response (behavior) has more than 2 variables.
Logistic Fit of Behavior By total humans
Whole Model Test
Model
-LogLikelihood
DF
ChiSquare
Prob>ChiSq
Difference
37.2401
11
74.48025
<.0001*
Full
1162.7796
Reduced
1200.0197
RSquare (U)
0.0310
AICc
2371.15
BIC
2468.39
Observations (or Sum Wgts)
660
Measure
Training
Definition
Entropy RSquare
0.0310
1-Loglike(model)/Loglike(0)
Generalized R-Square
0.1096
(1-(L(0)/L(model))^(2/n))/(1-L(0)^(2/n))
Mean -Log p
1.7618
∑ -Log(ρ)/n
RMSE
0.7987
√ ∑(y)²/n
Mean Abs Dev
0.7918
∑ |y|/n
Misclassification Rate
0.6727
∑ (ρ≠ρMax)/n
N
660
n
Parameter Estimates
Term
Estimate
Std Error
ChiSquare
Prob>ChiSq
Intercept[Drink]
Unstable
9.3119005
1537.0201
0.00
0.9952
total humans[Drink]
Unstable
-13.895268
1537.0192
0.00
0.9928
Intercept[Feed]
-1.5746952
0.2067421
58.01
<.0001*
total humans[Feed]
0.45943506
0.0703651
42.63
<.0001*
Intercept[Groom]
-3.8964691
0.7363762
28.00
<.0001*
total humans[Groom]
0.17142825
0.2657919
0.42
0.5189
Intercept[Groom Recipient]
-5.9062151
1.021258
33.45
<.0001*
total humans[Groom Recipient]
0.60419887
0.1604264
14.18
0.0002*
Intercept[Hang]
-3.4626526
0.5849713
35.04
<.0001*
total humans[Hang]
0.187694
0.2073532
0.82
0.3654
Intercept[Not Visible]
-0.9158515
0.1862225
24.19
<.0001*
total humans[Not Visible]
0.35203714
0.0696868
25.52
<.0001*
Intercept[Other]
-7.0115111
1.4481919
23.44
<.0001*
total humans[Other]
0.71085044
0.1806613
15.48
<.0001*
Intercept[Rest - Sleep]
-2.0491431
0.2866187
51.11
<.0001*
total humans[Rest - Sleep]
0.25952368
0.0987496
6.91
0.0086*
Intercept[Rest - Still]
-1.703556
0.2215666
59.12
<.0001*
total humans[Rest - Still]
0.40532436
0.0739462
30.05
<.0001*
Intercept[Self groom]
-5.34457
1.6699724
10.24
0.0014*
total humans[Self groom]
0.09443149
0.6681153
0.02
0.8876
Intercept[Travel]
-1.709588
0.2321228
54.24
<.0001*
total humans[Travel]
0.34947804
0.0784157
19.86
<.0001*
For log odds of Drink/Vocalize, Feed/Vocalize, Groom/Vocalize, Groom Recipient/Vocalize, Hang/Vocalize, Not Visible/Vocalize, Other/Vocalize, Rest - Sleep/Vocalize, Rest - Still/Vocalize, Self groom/Vocalize, Travel/Vocalize
