vt_sailor
Loading R .rds files into JMP
We have some equipment that publishes results in an .rds files--an R file format.  I can find how to read a JMP file into R, but I'd like to read the R / .rds file into JMP.  Does anyone have some code snippets that would do this?
Thanks!
Ray Bunkofske
andersonmj2
Re: Loading R .rds files into JMP
My approach would be to simply call out to R on your computer and execute the readRDS() function to pull the data in that way.
vt_sailor
What I know about R you can put in a thimble. Can I set it up as a JMP function so that the user can stay within the JMP script? I'm trying to build a dataflow that: looks in a directory, loads the R files, creates several JMP reports and saves the JMP data files with the reports embedded. That way folks can view the reports, and do further drill-down with the complete data file.
You can run this from JMP, however you will have to submit r code that opens the .rds file in r, and then use an r get() function to transfer the data frame in r to a data table in JMP.
See the JSL Scripting Guide section on Extending JMP
     Help==>Books==>Scripting Guide
Cougar
Anyone has an easy solution? thanks
