tom_abramov
Level V
List as data table variable
I need to save the list as data table variable.
My List = {1,"2"};
DT << Set Table Variable( "The List", My List ); //doesn't work - the value of the variable is string "List"
And then, how do I assign the list to some new variable
MyNewListVariable = DT<< Get Table Variable( "The List" ); // Would it work?
Thank you.
tom_abramov
Level V
Re: List as data table variable
Thank you,
Below is the code which worked for me:
dt = New Table("Table");
MyList = {"A","B"};
dt << Set Table Variable("Var", Char(MyList) );
list_as_string = dt << Get Table Variable( "Var" );
list_as_list = Parse(list_as_string);
JMP Table Variables are all stored as character strings, so your list will be returned as a character string, and you will have to convert it within your application.
tom_abramov
Level V
Thank you,
MyList = {"A","B"};
