pmroz
List Minus or Subtraction
Hello all,
Is there a way in JMP to subtract one list from another, kind of like a SQL MINUS? For example I want to do the following:
biglist = {"a", "b", "c", "d", "e", "f", "g"};
shortlist = {"a", "b", "c"};
newlist = biglist MINUS shortlist;
Newlist would be {"d", "e", "f", "g"};
Thanks,
Peter
pmroz
Re: List Minus or Subtraction
Well I figured something out:
style="font-size: 10pt; font-family: "Courier New"; color: black;">biglist
style="font-size: 10pt; font-family: "Courier New"; color: navy;">=
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"a"
style="font-size: 10pt; font-family: "Courier New"; color: navy;">,
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"b"
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"c"
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"d"
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"e"
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"f"
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"g"
style="font-size: 10pt; font-family: "Courier New"; color: black;">}
style="font-size: 10pt; font-family: "Courier New"; color: navy;">;
style="font-size: 10pt; font-family: "Courier New"; color: black;">shortlist
style="font-size: 10pt; font-family: "Courier New"; color: black;">newlist
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">for
(i
style="font-size: 10pt; font-family: "Courier New"; color: teal;">1
i
style="font-size: 10pt; font-family: "Courier New"; color: navy;"><
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">nitems
style="font-size: 10pt; font-family: "Courier New"; color: black;">(
style="font-size: 10pt; font-family: "Courier New"; color: black;">biglist)
i
style="font-size: 10pt; font-family: "Courier New"; color: navy;">++,
style="">
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">if
style="font-size: 10pt; font-family: "Courier New"; color: navy;">!
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">contains
biglist[i])
style="">
style="font-size: 10pt; font-family: "Courier New"; color: green;">//
then
style="">
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">insertinto
biglist[i])
style="">
style="font-size: 10pt; font-family: "Courier New"; color: black;">)
But it would be great if there were an easier way.
I'm actually trying to see the difference between two datasets. I can do a difference between two ID-value columns, but ideally I'd like to see all the rows in one dataset that are not in the other. A SQL MINUS would be perfect!
Regards,
Peter
aim
aim
The SQL MINUS functionality can be simulated in JMP by data table "Update" method. It works like this:
- take two data tables, which have some common data
- add a dummy column with all values as "1" to first dt;
- add a dummy column with the same name to the second dt, but this time with all values as "0";
- "update" first dt with second dt by matching columns (excluding dummy ones!)
After the update, dummy column in first table will have "0" for rows that are matched to the second dt, and "1" for rows that are different. What is left at this point is to subset all this rows with dummy value "1" to get data table with differences.
Here is a function, which can get difference between two data tables using method described above, and a couple examples of using it.
style="MARGIN-BOTTOM: 0pt; LINE-HEIGHT: normal; mso-layout-grid-align: none">
style="FONT-SIZE: 10pt; COLOR: green; FONT-FAMILY: 'Courier New'">/////////////////////////////////////////////////////////////////////////////////
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">
style="FONT-SIZE: 10pt; COLOR: green; FONT-FAMILY: 'Courier New'">//Function
jmp_SQL_MINUS
style="FONT-SIZE: 10pt; COLOR: green; FONT-FAMILY: 'Courier New'">//performs
substraction on data sets, similar to "SQL MINUS"
style="mso-spacerun: yes">
result_dt = dt1 - dt2
style="FONT-SIZE: 10pt; COLOR: green; FONT-FAMILY: 'Courier New'">//MUST have
at least one column with similar name in BOTH data tables
style="FONT-SIZE: 10pt; COLOR: green; FONT-FAMILY: 'Courier New'">//Arguments:
dt1 - first table
dt2 - second table
new_table_name - name of the resulting
table
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">jmp_SQL_MINUS
style="FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: 'Courier New'">=
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">Function
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">(
{dt1
style="FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: 'Courier New'">,
dt2
new_table_name}
style="mso-tab-count: 1">
{Default
Local}
style="FONT-SIZE: 10pt; COLOR: green; FONT-FAMILY: 'Courier New'">//Get list
of columns with matching names between 2 tables
cl1
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'"> dt1
style="FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: 'Courier New'"><<
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'"> get column
names( string )
style="FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: 'Courier New'">;
cl2
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'"> dt2
names( string )
dt2_nc
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">N
Cols
col_str
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">"Match
Columns("
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">For
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'"> ii
style="FONT-SIZE: 10pt; COLOR: teal; FONT-FAMILY: 'Courier New'">1
style="FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: 'Courier New'"><=
dt2_nc
ii
style="FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: 'Courier New'">++,
style="mso-tab-count: 2">
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">If
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">Contains
cl1
cl2[ii] )
style="mso-tab-count: 3">
col_str
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'"> col_str
style="FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: 'Courier New'">||
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">":Name(\!""
cl2[ii]
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">"\!")==:Name(\!""
cl2[ii]
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">"\!")"
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">If(
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">ii
style="FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: 'Courier New'">==
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">dt2_nc
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">""
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">","
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">)
col_str
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">")"
style="FONT-SIZE: 10pt; COLOR: green; FONT-FAMILY: 'Courier New'">//Build
"update" expression using template
column_expr
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">Parse
template_expr
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">Name
Expr
Update( With( _dt2_ )
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'"> _col_list_
update_expr
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">Substitute
Expr
template_expr )
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">Expr
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'"> _dt2_
Expr
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">Data
Table
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'"> get name
Expr
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'"> column_expr
style="FONT-SIZE: 10pt; COLOR: green; FONT-FAMILY: 'Courier New'">//Create
helper column with unique name
dt1
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">New
Column
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">"_f_l_a_g_"
numeric
continuous
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'"> Set Each
Value(
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'"> )
dt2
Column
numeric
continuous
Value(
style="FONT-SIZE: 10pt; COLOR: teal; FONT-FAMILY: 'Courier New'">0
style="FONT-SIZE: 10pt; COLOR: green; FONT-FAMILY: 'Courier New'">//Run
"update" expression. After this step helper column shows "0" for values that
are matched between two tables,
style="FONT-SIZE: 10pt; COLOR: green; FONT-FAMILY: 'Courier New'">//and "1"
for values that are different
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">Eval
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'"> update_expr
style="FONT-SIZE: 10pt; COLOR: green; FONT-FAMILY: 'Courier New'">//Extracting
list of values that are not matched
dt1
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'"> Clear
Select
dt1
Column Selection
dt1
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'"> Select
Where(
style="FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: 'Courier New'">:
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">Name(
dt3
Subset( Output Table( new_table_name )
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'"> Copy
formula(
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'"> Ignore
Missing (
style="FONT-SIZE: 10pt; COLOR: green; FONT-FAMILY: 'Courier New'">//Cleanup
dt1
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'"> Delete
Column(
dt2
Column(
dt3
Column(
style="FONT-SIZE: 10pt; COLOR: green; FONT-FAMILY: 'Courier New'">//Outputting
result
dt3
style="FONT-SIZE: 10pt; COLOR: green; FONT-FAMILY: 'Courier New'">//Example of
usage
style="FONT-SIZE: 10pt; COLOR: green; FONT-FAMILY: 'Courier New'">//open "big
table"
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">Open
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">"$SAMPLE_DATA/Big
Class.jmp"
style="FONT-SIZE: 10pt; COLOR: green; FONT-FAMILY: 'Courier New'">//subset of
"big table", only 10 rows and a couple of columns
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">sub_dt
Table
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">"Big
Class"
Subset(
Copy
formula(
Sample
Size(
style="FONT-SIZE: 10pt; COLOR: teal; FONT-FAMILY: 'Courier New'">10
columns(
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">name
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">age
style="FONT-SIZE: 10pt; COLOR: green; FONT-FAMILY: 'Courier New'">//result
data table is a difference between "big" table and its subset
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">result_dt
jmp_SQL_MINUS( dt
sub_dt
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">"Difference
between dt and sub_dt"
style="FONT-SIZE: 10pt; COLOR: green; FONT-FAMILY: 'Courier New'">//Second
example
style="FONT-SIZE: 10pt; COLOR: green; FONT-FAMILY: 'Courier New'">//Open big
data table
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">"$SAMPLE_DATA/Equity.jmp"
data table with items that needs to be excluded
Table
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">"Exclude
Items"
Add
Rows(
style="FONT-SIZE: 10pt; COLOR: teal; FONT-FAMILY: 'Courier New'">2
Column
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">"REASON"
Character
Nominal
Values( {
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">"HomeImp"
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">"DebtCon"
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">}
Column
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">"JOB"
Character
Nominal
Values( {
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">"Other"
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">"Mgr"
data table has only filtered items
jmp_SQL_MINUS( dt
sub_dt
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">"Filtered"
style="MARGIN-BOTTOM: 0pt">
This isn't exactly the same problem, but it also would be worth taking a look at the thread below, which describes the usage of associative arrays to do something similar: http://support.sas.com/forums/thread.jspa?messageID=34183薇
aim
aim
The associative arrays can be quite useful, but not when your data have duplicate values that need to be preserved:
Say, there are two lists:
list1 = {"a", "b", "c", "d", "e", "f", "g", "a", "b", "c"};
list2 = {"d", "e", "f", "g", "ss"};
Subtracting list2 from list1 using a direct method results in list: {"a", "b", "c", "a", "b", "c"}, while doing this using associative array method results in list: {"a", "b", "c"}. So, which method to use depends on the nature of data in lists.
If you deal with large 1D lists with duplicates, here is the faster version of the list subtraction routine:
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">List_Minus
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'"> (
{list1
list2}
{Default
Local}
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">While
Items
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'"> list2
style="FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: 'Courier New'">>
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">Remove
From
list1
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">As
List
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">Loc
list1
list2[
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">]
From
list2
List
list2
list2[
list1
To compare how much faster, here is the test routine, and its results:
{list1
list2}
{Default
Local}
Items
From
list1
List
list1
list2[
From
list2
List
list2
list2[
list1
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">slow_List_Minus
{list1
list2}
{Default
Local}
newlist
Items
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'"> list1
i
style="FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: 'Courier New'">!
list2
list1[i] )
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">Insert
Into
newlist
list1[i] )
newlist
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">vv
List
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">J
style="FONT-SIZE: 10pt; COLOR: teal; FONT-FAMILY: 'Courier New'">100000
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">Random
Integer
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">)))
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">vsm
List
Integer
style="FONT-SIZE: 10pt; COLOR: teal; FONT-FAMILY: 'Courier New'">90
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">t1
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">Tick
Seconds
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">()
newlist
List_Minus(vv
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">vsm)
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">t2
Seconds
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">Show
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">"List_Minus
time:"
style="FONT-SIZE: 10pt; COLOR: #0000dd; FONT-FAMILY: 'Courier New'">Round
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'"> t2
style="FONT-SIZE: 10pt; COLOR: navy; FONT-FAMILY: 'Courier New'">-
t1
style="FONT-SIZE: 10pt; COLOR: teal; FONT-FAMILY: 'Courier New'">3
Seconds
newlist
slow_List_Minus(vv
Seconds
style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: 'Courier New'">"slow_List_Minus
time:"
t1
Here is the script output (on modestly fast PC):
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">"List_Minus
time:"
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">Round(::t2 -
::t1, 3):0.217
style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: 'Courier New'">"slow_List_Minus
time:"
::t1, 3):229.75
Using associative array would be fast, but would result in a list 89 items long (numbers from 1 to 89).
