Scorpio
Linearity and Bias study
Hello Community,
While performing the Linearity and the bias study, if the P value for the Bias is less than 0.05--then that marks the presence of bias in the scale. Further, the average bias value is less than the resolution of my scale and secondly, the bias is not in increasing or decreasing fashion but, randomly fluctuated at different standard reference weights.
Can it be concluded that the scale has no bias(as it will be not reflected on the scale) or is there other way to interpret this results?
statman
Re: Linearity and Bias study
Sorry, it is impossible for me to comment without context.
That clearly didn’t stop you from commenting anyways….
How about a more helpful response: Could you please add some more context so that we can try to help?
statman
I apologize, I could have asked for more context in a more friendly way.  Without knowing what you are measuring, how the study was conducted, what comparisons were being made that resulted in a p-value, what the sources of variation are in the study, what is the source of the potential bias, etc. Also, if you could, perhaps, attach a JMP data table or a coded data table if the content is not for public consumption that would be helpful as well.
P_Bartell
Level VIII
Can you share at a minimum the associated graphics that JMP produced? In general p-values are the last thing I look at...and the first thing I look at are the plots. They should tell you the story more than a p-value.
