crofut
Linear Contrast in Fit Model
I've noticed that when using Fit Model (even for a simple one-way ANOVA), that the Linear Contrast is not correctly saved when I save the script to the data file to re-execute at a later time.  Also, since I'm creating (attempting) several contrasts, is there an easy way to label/title each constrast?
Re: Linear Contrast in Fit Model
Hi Steve!
This is a bug in version 13 of JMP. Updating to 13.2 will fix the problem.
From the 13.2 release notes on fixes made:
Standard Least Squares • When you create an LSMeans Contrast and then save the script for the analysis, the LSMeans Contrast is saved correctly in the script. • The Contrast Specification boxes are aligned correctly
As for the labeling of the contrasts, I don't know of any way to easily do that.
Dan Obermiller
I'm not seeing a problem. Which version of JMP are you using? Can you show the script that is saved along with the output that the script SHOULD be producing?
Dan Obermiller
crofut
Hi Dan,  I'm using JMP PRO 13.0 (64-bit).  I can't email JMP files (security blockage at company).  SO I've attached a PPT file that shows a simple data table, with the script.  It also shows the original output, and the output when the script is re-executed.
Thanks,
Steve
Hi Steve!
Dan Obermiller
ghartel
I'm on version 14.1 and it seems there is a similar problem. I'm using Generalized Linear Model to fit a logistic and I'm using contrast to compare levels of a categorical variable. It works fine point and click but the script only saves "Run(Contrast( 1 ))" which requires the contrasts to be specified manually again. I don't see anything in the documentation about how to specify the contrasts via script. Is this just not implemented?
jules
Hi @crofut,
It looks like Dan addressed your main issue, but with regard to labeling, when I need to keep track of several contrasts I find it's helpful to simply rename the outline boxes (i.e. double click on the outline box title). This renaming is preserved in the script you save for the report.
I hope this helps!
Julian
