Timo51
Line graph with multiple trends on same graph
Hello JMP. I'm trying to design a line graph with multiple entries to observe trends on the same graph. I can do this in Excel, but not in JMP.
Pictured below is the example in Excel. How can I do this in JMP?
Re: Line graph with multiple trends on same graph
Could you attach the data (image of the data isn't really helpful)?
You want to stack your data
And from here you can create the plot using Overlay for the Person
Have you read the documentation section in the Help pull down menu called Essential Graphing?  It will show you how to use Graph Builder to do what you need.
