Sarah1
Write Slope to Data Table
I have a data table with variable data over time per batch.  Each variable value is on an individual row with it's corresponding time.  I am looking to write the slope of the linear fit of that X(time) to Y(variable).  I have done a bivariate fit per batch with a linear fit to get the slope per batch.  I am looking to write this value back to the data table.  The goal is to add a column of each batches' slope to compare between batch variability.  There are 800+ batches, so copy and paste from the graphs is not an option.
Re: Write Slope to Data Table
If your data are similar to this
You can run your Bivariates
And then right click on any of the Parameter Estimates tables and select
      Make Combined Data Table
It will then create a table with the Intercepts and Time Estimates for each batch
You can then simply delete the intercept rows, and you will have a table of all of just your Time Estimates, which are your slopes.
