vharibal
Line Up box runs with JMP 17.2 but not with JMP 18.1
I am running distribution platform to store multiple graphs in 4 columns per row
this ran perfectly with JMP 17.2, but isnt running with JMP 18.2
Can someone please help?
Lub = lineup box(
Dist_ BLE = dt_BLE  << Distribution(
    Continuous Distribution(
		Column( :"Pout_accuracy"n),
		Quantiles( 0 ),
		Vertical( 0 ),
		Count Axis( 1 ),
		Show Counts( 0 ),
		Dispatch(
			{"Pout_accuracy"},
			"1",
			ScaleBox,
			{ Inc( 0.5 ),
			Minor Ticks( 4 )}
		Dispatch( {"Pout_accuracy"}, "Quantiles", OutlineBox, {Close( 1 )} ),
		Dispatch(
			{"Pout_accuracy"},
			"1",
			ScaleBox,
			{Add Ref Line( -2, "Solid", "Red", "LSL", 1 ),
			Add Ref Line( 2, "Solid", "Red", "USL", 1 )}
	By("PktType"n, "Freq"n , "Txpwr"n , "BT_PA"n, "Temp"n )
jj = New Window( "The Output_BLE",  << journal,  V List Box(Lub) );
Lub << N Col( 4 );
jj << Save Journal ("C:\Users\NXF90574\Desktop\bt test\bt_1\journal_dist_BLE.jrn");
jj << Save PDF( "C:\Users\NXF90574\Desktop\bt test\bt_1\BLE_Dist.pdf", show page setup(0), potrait(1) );
Re: Line Up box runs with JMP 17.2 but not with JMP 18.1
It might but I would use N Across
dist = dt << Distribution(
	Continuous Distribution(Column(:height), Process Capability(0)),
	By(:age),
	Group Options(Layout("Arrange in Rows", N Across(4)), Return Group(1))
dist << journal;
By is handled in different manner in JMP18. I suggest you check out how you could do this in JMP18 as it has more options
vharibal
Sure will check
So lineupbox won’t work with distribution platform anymore as it does with jmp 17?
mmarchandFSLR
Line Up Box() takes NCol() as its first argument.  I use it in JMP 18 to display some reports.
*edit
Never mind.  I see you sent the message later to the box.
	By(:age),
dist << journal;
