Dennisbur
Limits per parameter in Distribution Graph
Hello
I try to build a distribution graph per PIN_TEST
very important to note that each PIN_TEST has a different limit, and I need to show it in the graph
For example, like this distribution graph included LSL and USL limits.
Re: Limits per parameter in Distribution Graph
You might start with the JMP Documentation about managing multiple spec limits. You will find more help there if you search 'spec limits.'
The Process Capability platform might also be helpful when you have more than one parameter to assess.
The Process Screening platform can help validate your capability analysis by assessing the stability of more than one parameter at a time.
