MahaRabeh
Label incorrect when exporting Dashboard to PDF with JSL
I am using a JSL script to save a dashboard to PDF.
In my graphs i have bars labeled by row with text format.
For some reasons when exporting to PDF the label is showing numbers and not the right labels as in the graphs.
This is only happening when i use the JSL script. If i manually export to PDF, the label is correct.
Is something wrong with my script?
This is the script i am using:
Author = "My name";
Title = "Dashboard";
dbwin = window("Dashboard");
myjrn = New Window("DashBoard Report", <<Journal);
dbwin << Journal();
myjrn <<Set page setup(
	margins( 0.4, 0.2, 0.4, 0.1 ),
	scale( 0.35 ),
	portrait( 1 ),
	paper size( "A4" )
myjrn << Set Print Footers(
  Author/*left*/,
  "&d;"/*center*/,
  "Page &pn; of &pc;"/*right*/
  myjrn << Set Print headers(
 " " /*left*/,
  " "/*center*/,
  " ";/*right*/
SaveLocation="C:\Users\Chart\";
path = SaveLocation || title || Char(Long Date( Today() )) || ".pdf";
myjrn <<Save PDF( path );
current journal() << close window();
Thanks.
MahaRabeh
Re: Label incorrect when exporting Dashboard to PDF with JSL
Problem solved by freezing the journal. Used command:
dbwin <<journal(freeze pictures);
