pmroz
Jump out of a function?
Is there a way to cleanly jump out of a function?  Something like the break() function in a for loop.  I've tried throw() but that stops the entire JSL script.
ms
Super User (Alumni) ms
Re: Jump out of a function?
I often enclose error prone expressions in Try() without Throw(). The placement of Try() – within the function or "around" the function call – depends if I only want to escape parts of the function or escape it completely in case of an exception. Throw() halts execution and I tend to use it mainly for debugging.
Compare these examples and their output:
//Try() inside the function escapes chosen parts of function, script execution continues.
exsqr = Function( {x},
  x2 = Try( x * x, "Error, move on!" );
  Show( "Show this even if x is NaN" );
  x2;
sq = exsqr( "q" );
Show( sq, "function escape failed, but script continued" );
//Try() enclosing the function call escapes function, script execution continues.
  x2 = x * x;
  Show( "Don't show this if x is NaN" );
  x2;
sq = Try( exsqr( "q" ) );
Show( sq, "function escape succeeded!" );
//Try() with Throw() escapes function and script.
  x2 = Try( x * x, Throw( "Error, stop here!: " || Char( exception_msg ) ) );
sq = exsqr( "q" );
Show( sq, "script stopped!" );
andrewtkarl
Could you use return()?
Yes, return() will break out of a function
bswedlove
I am getting an error when trying to exit a function with return().
I get the error when I make a button box
bb = Button Box("SpecsAuto")
then attach a function
bb << Set Function( Return() )
then click the box.
Here is demo code to reproduce the error:
nw = New Window("Win1");
nw << Append(bb = Button Box("SpecsAuto"));
bb << Set Function(
	Print("A");
	Return();
	Print("B");
bb << Click();
Level XIII
set function() also works if no function is provided - like in your script.
To use the magic of return(), you have to put it inside a function:
bb << Set function(Function({},
	Print("A");
	Return();
	Print("B");)
bb << Click();
