Dennisbur
Journal
I have a journal with a few graphs in a vertical position
but I didn't find how to change the journal to a horizontal position arranged in rows (for example 3) ?
Re: Journal
In Journals, you can change your cursor from the Arrow ('A' keyboard shortcut) to the Selector ('S' keyboard shortcut). Then, you can click to select, followed by drag to re-arrange. While dragging the blue line indicates where the selection will be moved to. To move horizontally, you'd drag until you see a blue line like the example below.
