lodey101
Joining Multiple Data Table using a loop
Hi there,
Currently as part of my analysis I am creating multiple files based on control chart limits.These files are outputted as Untitled. I need to join all the analysis together but the problem that I have is that I need to exclude some data tables from my join. There are 2 tables that I need to exclude from my loop - Ref Data and Limits_Key.
See Below:
I was using this code to place all the tables into a list:
num_tables = ntable();
dataset_list = {};
For (z = 1, z <= num_tables, z++,
    dt = Data Table(z);
    column_names = dt << get column names;
    valid_columns = 1;
    if (valid_columns,
        one_name = dt << Get Name;
        Insert Into(dataset_list, one_name);
);    // end for
//show(dataset_list);
num_tables = nitems(dataset_list);
For( q = num_tables, q >= 1, q--,
  If( !Starts With( dataset_list, "Untitled" ),
  Remove From( dataset_list, q )
Show(dataset_list);
I was hoping to use something like the following to join the tables (excluding the 2 mentioned above)
t_count = (N Table());
show (t_count);
t_count = (t_count) -2;
dt_old = Data Table(t_count);
show(dt_old);
Show(dt_old << get name());
dt_new = Data Table("temp_ref");
For(i = 3, i <= t_count, i++,
  //show(Data Table);
    dt_old = dt_new;
    dt_new = dt_old << Join(
        With(Data Table(i)),
        Merge Same Name Columns,
        By Matching Columns(:_LimitsKey = :_LimitsKey,
  :_Screened = :_Screened,
  :SUBSET = :SUBSET),
        Drop multiples(0, 0),
        Name("Include non-matches")(1, 1),
        Output Table( "Limits" )
    Close(dt_old);
Could anyone help me out or give me a few pointers?
pmroz
Re: Joining Multiple Data Table using a loop
You can filter out unneeded tables in the very first loop.  You'll end up with a table called LimitsNNN, where NNN is the number of Untitled tables.  Try something like this.
num_tables = N Table();
dataset_list = {};
For( z = 1, z <= num_tables, z++,
    dt = Data Table( z );
    If( Starts With( one_name, "Untitled" ),
        Insert Into( dataset_list, one_name )
);    // end for
Show( dataset_list );
dt_old = data table(dataset_list[1]);
for (i = 2, i <= nitems(dataset_list), i++,
    dt_new = data table(dataset_list[i]);
    join_name = "Limits" || char(i);
    dt_old << join( with(dt_new),
            :SUBSET = :SUBSET
        Drop multiples( 0, 0 ),
        Name( "Include non-matches" )(1, 1),
        Output Table( join_name )
    close(dt_old, nosave);
    dt_old = data table(join_name);
pmroz
dataset_list = {};
);    // end for
            :SUBSET = :SUBSET
