BookmarkSubscribeRSS Feed
Hegedus
Community Trekker
Jun 23, 2011
Join - This should be simple
OK.
DT1 has 1 column on interest named DUT#
DT2 has a variable number of columns.
I want to script a join that takes all the columns on DT2 and joins it with the single DUT# column in data table 1 by using Row numbers.
What is Select and selectwith expecting, a list, a string, .... "A pretty please"
How do I script this ?  The manual is completely worthless.
Current Data Table( CT );
ListofPads = CT << get column names;
CT1 = Data Table( CT ) << Join( With( Data Table( DUTTable ) ),select(ListofPads),selectwith(:DUT#), By Row Number);
ms
Jun 23, 2011
Solution
Re: Join - This should be simple
Try to put the column list within Eval():
..., select(Eval(ListofPads)),...
8 REPLIES 8
vince_faller
Mar 17, 2015
Let JMP make the script for you.  Just join the table and select source on the output table.
Data Table( "Untitled" ) << Join(
  With( Data Table( "Untitled 2" ) ),
  By Row Number
Hegedus
Community Trekker
Jun 23, 2011
This approach does not work.
The script produced by JMP has specific column names and as such is not flexible to a different set of names or number of columns.
ms
Jun 23, 2011
Solution
Hegedus
Community Trekker
Jun 23, 2011
Thank you that worked.
Broader question, where in the documentation would it explain that that was necessary?
vince_faller
Mar 17, 2015
If DT1 only has 1 column and you're trying to join all the columns for DT2, why are you selecting columns?  My apologies, I must not have understood your question.
Hegedus
Community Trekker
Jun 23, 2011
In JMP 11 you can't update by row position  so I would have to create and delete rows and in JMP 12 it deletes the data.  I reported the bug.
vince_faller
Mar 17, 2015
You're trying to update?
In Join you just have to change the matching specification.  (In JMP 11.2.1)
chungwei
Jun 23, 2011
You can use the key word "all" in place of the list of columns if you want to include all the columns from one table,
In the following example, I am joining Big Class to untitled 9 by row number.
I want to include only :Column 1 from untitled 9, and all the columns form Big Class.
Data Table( "Big Class" ) << Join(
  With( Data Table( "untitled 9" ) ),
  SelectWith( :Column 1 ),
  Select( all),
  By Row Number
