This widget could not be displayed.
Created:
Feb 28, 2009 11:47 PM
| Last Modified:
Feb 28, 2009 8:47 PM
(9643 views)
JMP reports the following parameters with respect to a fitted Johnson su distribution 1) shape (lambda), 2) shape (delta), 3) Location (BETA), and 4) Scale (sigma).
I would like to use the Johnson su distribution in the discrete element simulation program EXTEND6. EXTEND6 does accommodate the Johnson su but requires the following parametric inputs 1) Lambda, 2) Gamma, 3) delta, and 4) Location.
I am concerned about putting the right paramaters from JMP into the correct fields in EXTEND6.
Can anyone out there provide some insight. I have searched the software manuals for each program and have come up empty.
Thank you!
