- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Get Direct Link
Jmp : select where
Hello I would try to generate new table with select where in a script and merge the subset table with another one
I succeed to generate a successful script except when the Select Where doesn't find row with the criteria ?
do you know how I can skip the join table part in my script if select where return nothing
regards
sebastien
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Re: Jmp : select where
There are probably several ways to do this. Here's an idea that should work if Select Where() have been applied:
If(N Row(dt << Get Rows Where(Selected())) > 0,
dtsub << join(...)
Another idea without Select Where() that makes a subset only if any rows match the criteria (compare with "F" in place of "Q"):
r = dt << get rows where(:sex == "Q");
If(N Row(r),
(dt << subset(rows(r))) << join(With(dt))
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
hi seb38.cremer,
MS gave the right answer. yet, if it was not explicit enough thy the following:
// open data table and make some changes
dt = Open( "$SAMPLE_DATA/Big Class.jmp" ) <<
set name( "table" ) <<
New Column( "Weight/Height", formula( :weight / :height ) );
// open another data table
dt2 = Open( "$SAMPLE_DATA/Big Class.jmp" );
// instead of using select use get rows where - it is more robust
choosen = dt2 << get rows where( :age == 12 );
// see if any were chosen. if yes subset and join
If( N Row( choosen ) > 0,
dt3 = dt2 << subset(
Rows( choosen ),
selected columns( 0 ) // brings all columns
// now join
dt3 << Join(
With( data table ("table") ),
By Matching Columns( :name = :name ),
Drop multiples( 0, 0 ),
Name( "Include non-matches" )(0, 0),
Preserve main table order( 1 )
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Two more examples using If(!isempty and my preferred try( method examples:
dt << set name( "table" ) <<
dt2 << Select where(:sex == "Q");
dt3 = dt2 << Subset(
Selected Rows( 1 ),
Selected columns only( 0 )
If(!isempty(dt3), //if selected rows == 0 dt3 is an empty variable
dt4 = dt << Join(
With( dt3 ),
Include Nonmatches( 0, 0 ),
Preserve main table order( 1 )), //no table print error log
print("Empty subset table")
try(dt4 = dt << Join(
With( dt3 ),
, //catch expresion
Print("Join Failed"));
